I’m having a weird problem w/ the 8 servo controller.
I’m using a serial->usb converter which seems to be recognized by the system, as /dev/ttyUSB0 is created when you plug it in.
I’m running a test program that just opens the port, moves a servo, and closes the port. When I run the program, the yellow light will blink off, and then blink on again when the program is done running, but will not actually move the servo. The green light never comes on.
I’m using code from one of the example projects, and also from Adam(nexisnet). Here is my code:
#include <stdio.h> /* Standard input/output definitions */
#include <string.h> /* String function definitions */
#include <unistd.h> /* UNIX standard function definitions */
#include <fcntl.h> /* File control definitions */
#include <errno.h> /* Error number definitions */
#include <termios.h> /* POSIX terminal control definitions */
#include <iostream>
using namespace std;
int open_port();
int put(int servo, int angle, int port);
int input;
int main() {
struct termios options;
int count,ret;
int fd;
fd = open("/dev/ttyUSB0", O_RDWR | O_NOCTTY | O_NDELAY);
if (fd == -1) {
cout<<"Failed to open device";
return 0;
else
fcntl(fd, F_SETFL, 0);
tcgetattr(fd, &options);
cfsetospeed(&options, B9600);
cfsetispeed(&options, B9600);
options.c_oflag = 0;
options.c_cflag |= (CLOCAL | CREAD); /* enable */
options.c_cflag &= ~PARENB; /* 8N1 */
options.c_cflag &= ~CSTOPB;
options.c_cflag &= ~CSIZE;
options.c_cflag |= CS8;
/* set all of the options */
tcsetattr(fd, TCSANOW, &options);
int servo=7;
int angle=3000;
unsigned char buff[6];
unsigned short int temp;
unsigned char pos_hi,pos_low;
temp=angle&0x1f80;
pos_hi=temp>>7;
pos_low=angle & 0x7f;
buff[0]=0x80;//start byte
buff[1]=0x01;//device id
buff[2]=0x04;//command number
buff[3]=servo;//servo number
buff[4]=pos_hi;//data1
buff[5]=pos_low;//data2
int result=write(fd,&buff,6);
cout<<endl<<"Result of write operation: "<<result<<endl;
int closereturns = close(fd);
cout<<"Result of port closing: "<<closereturns<<endl;
return 0;
The code returns 6 at output, and 0 at port close… neither one is an error code. The output of the program is always the same… 6 - 0.
The weird thing is… the only time it HAS worked, was when it was plugged in through a non-powered USB hub. And it worked erratically then… it would move the servos into position, but would sometimes result in the red error light… i could run the same code 10 times and get about 3 different results…
I’m running ubuntu 7.1 gutsy.
Thanks,
Colin
