My name is Lars and I’m quite new to this, so please forgive any obvious fault I might done…
I have the following code and what I try to achive is after each sequence I “turn off” my servos to avoid servo jitter. I know this might be the wrong way to solve this, but I have a robot for display only, and I need it to be “quiet” in between the sequences.
My problem is that even do I try to set the speed and acc. it is 100% on both after I turned the servos off the first time. To solve this
I added the speed and acc. parameters in the begining of each sequence with out success. Can anyone explain what I doing wrong?
# When the Maestro script is not doing anything else,
# this loop will listen for button presses. When a button
# is pressed it runs the corresponding sequence.
begin
button1 if sequence1 endif
button2 if sequence2 endif
button3 if sequence3 endif
repeat
# These subroutines each return 1 if the corresponding
# button is pressed, and return 0 otherwise.
# Currently button1 is assigned to channel 18,
# button2 is assigned to channel 17, and
# button3 is assigned to channel 16.
# These channels must be configured as Inputs in the
# Channel Settings tab.
sub button1
22 get_position 500 greater_than
return
sub button2
21 get_position 500 greater_than
return
sub button3
20 get_position 500 greater_than
return
# These subroutines each perform an arbitrary sequence
# of servo movements. You should change these to fit
# your application.
sub sequence1
80 0 acceleration
80 0 speed
80 1 acceleration
80 1 speed
80 2 acceleration
80 2 speed
80 3 acceleration
80 3 speed
#500 delay
5120 0 servo
5120 1 servo
5120 2 servo
5120 3 servo
3000 delay
7680 0 servo
7680 1 servo
7552 2 servo
7680 3 servo
500 delay
0 0 servo
0 1 servo
0 2 servo
0 3 servo
return
sub sequence2
80 0 acceleration
80 0 speed
80 1 acceleration
80 1 speed
80 2 acceleration
80 2 speed
80 3 acceleration
80 3 speed
80 6 acceleration
80 6 speed
80 7 acceleration
80 7 speed
80 8 acceleration
80 8 speed
80 9 acceleration
80 9 speed
80 10 acceleration
80 10 speed
#500 delay
5120 0 servo
200 delay
5120 1 servo
200 delay
5120 2 servo
200 delay
5120 3 servo
350 delay #extra delay between upper panels and side panels
5632 6 servo
200 delay
5120 7 servo
200 delay
4928 8 servo
200 delay
4928 9 servo
200 delay
4928 10 servo
200 delay
500 delay
7104 10 servo
200 delay
7040 9 servo
200 delay
6976 8 servo
200 delay
7040 7 servo
200 delay
7744 6 servo
200 delay
7680 3 servo
200 delay
7552 2 servo
200 delay
7680 1 servo
200 delay
7680 0 servo
500 delay
0 0 servo
0 1 servo
0 2 servo
0 3 servo
0 6 servo
0 7 servo
0 8 servo
0 9 servo
0 10 servo
return
sub sequence3
80 0 acceleration
80 0 speed
80 1 acceleration
80 1 speed
80 2 acceleration
80 2 speed
80 3 acceleration
80 3 speed
80 6 acceleration
80 6 speed
80 7 acceleration
80 7 speed
80 8 acceleration
80 8 speed
80 9 acceleration
80 9 speed
80 10 acceleration
80 10 speed
#500 delay
5120 0 servo
5120 1 servo
5120 2 servo
5120 3 servo
5632 6 servo
5120 7 servo
4928 8 servo
4928 9 servo
4928 10 servo
3000 delay #can be changed to 10000 for 10 seconds delay
7104 10 servo
7040 9 servo
6976 8 servo
7040 7 servo
7744 6 servo
7680 3 servo
7552 2 servo
7680 1 servo
7680 0 servo
500 delay
0 0 servo
0 1 servo
0 2 servo
0 3 servo
0 6 servo
0 7 servo
0 8 servo
0 9 servo
0 10 servo
return
