I have two Mini-Maestro 24 boards which I purchased together. The first one seems to work fine; when I plug it in Windows 7 recognizes it and I see two COM ports appear in the device manager:
I also see the Pololu USB Devices entry. When I load the Maestro Command Center it sees the device just fine and I can control my servos.
When I connect the other Mini-Maestro however (disconnecting the first board - I’m not trying to have two boards at once) it isn’t recognized. In Device Manager I only see this:
There is no “Pololu USB Devices” entry in the Device Manager when this board is plugged in. The green status light on the board blinks on a regular interval.
And, the Maestro Command Center doesn’t see anything.
What do I need to do to get this second board working?
Thanks!
