I'm a complete noob in AVR programming, so sorry if it's in some FAQ.
I'm getting an error when I'm connecting ARV Insight to target device.
- Code: Select all Expand
GDB
putpkt: write failed: No error.
GDB cannot connect to the target board using COM2.
Verify that the board is securely connected and, if necessary,
modify the port setting with the debugger preferences.
OK
Port setting is 9600 N 1 N the same in "Dev. manager" and "ARV Insight"
I'm trying to upload BlinkLED example with WinAVR Program menu, but getting the same error of course:
> "make.exe" program
avrdude -p atmega328p -P com2 -c stk500v2 -U flash:w:main.hex
avrdude: ser_send(): write error: sorry no info avail
make.exe: *** [program] Error 1
> Process Exit Code: 2
> Time Taken: 00:01
Code was compiled with WinAVR:
> "make.exe" all
-------- begin --------
avr-gcc (WinAVR 20100110) 4.3.3
Copyright (C) 2008 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
Compiling C++: main.cpp
avr-gcc -c -mmcu=atmega328p -I. -x c++ -gstabs -DF_CPU=8000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -fno-exceptions -Wall -Wundef -Wa,-adhlns=./main.lst -MMD -MP -MF .dep/main.o.d main.cpp -o main.o
main.cpp:3:1: warning: "F_CPU" redefined
<command-line>: warning: this is the location of the previous definition
Linking: main.elf
avr-gcc -mmcu=atmega328p -I. -gstabs -DF_CPU=8000000UL -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-adhlns=main.o -std=gnu99 -MMD -MP -MF .dep/main.elf.d main.o --output main.elf -Wl,-Map=main.map,--cref -lm
Creating load file for Flash: main.hex
avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock main.elf main.hex
Creating load file for EEPROM: main.eep
avr-objcopy -j .eeprom --set-section-flags=.eeprom="alloc,load" \
--change-section-lma .eeprom=0 --no-change-warnings -O ihex main.elf main.eep || exit 0
Creating Extended Listing: main.lss
avr-objdump -h -S -z main.elf > main.lss
Creating Symbol Table: main.sym
avr-nm -n main.elf > main.sym
Size after:
AVR Memory Usage
Device: atmega328p
Program: 192 bytes (0.6% Full)
(.text + .data + .bootloader)
Data: 0 bytes (0.0% Full)
(.data + .bss + .noinit)
-------- end --------
> Process Exit Code: 0
> Time Taken: 00:01
Any advice would e appreciated !
Thanks !
UPD: And I don't see pololu control panel either...
UPD2: TTL port - "This device cannot start. (Code 10)"
