Ardiuno UNO and a4983 with regulator and stepper motor
You might find this thread helpful:
Thanks Ben - why do I feel like I am missing parts on my circut here, when I look at those examples?
I cant rewire based on those specs, as from what I read this should all work with what I have… ideas?
I think Ben was mainly pointing you at the code that is attached to the first post of that thread. If you’ve soldered those header pins to the carrier, your connections should all be fine. The reason the wiring is different is because most people are using the version of the board without regulators on it.
Were you asking for an example of the code or of the soldering?
- Ryan
Hi again Ryan, I was asking for a sample of code to get the thing going so that I can make sure its all wired correctly.
A simple stepper sketch would be amazing please.
The forum thread Ben linked to has an attachment called StepperTester.pdf that is a simple stepper sketch. You can modify it to work for you by removing the lines that refer to the enablePin and setting dirPin and stepPin to the pins that match your wiring.
- Ryan
Ok Tried this - nothing…
#define stepPin 6
#define dirPin 7
//#define enablePin 4
// We set the enable pin to be an output
//pinMode(enablePin, OUTPUT);
// then we set it HIGH so that the board is disabled until we
// get into a known state.
//digitalWrite(enablePin, HIGH);
Serial.println("Starting stepper exerciser.");
pinMode(stepPin, OUTPUT);
pinMode(dirPin, OUTPUT);
int j;
// set the enablePin low so that we can now use our stepper driver.
//digitalWrite(enablePin, LOW);
// wait a few microseconds for the enable to take effect
// (That isn't in the spec sheet I just added it for sanity.)
delayMicroseconds(2);
// we set the direction pin in an arbitrary direction.
digitalWrite(dirPin, HIGH);
for(j=0; j<=10000; j++) {
digitalWrite(stepPin, LOW);
digitalWrite(stepPin, HIGH);
delayMicroseconds(1000);
Are we positive my connections on the board are correct?
Have you soldered your the header pins to the stepper driver board yet? There is no reason to expect anything to work with unsoldered pins, so it’s not worth trying to help you debug your system while there is still such a glaring problem. By the way, there really isn’t any down side to soldering first (soldering header pins does not commit you to any particular connections).
Point well taken Ben.
So please excuse my lack of knowledge here
The header pins are the strips of pins encased in plastic correct?
And do I only use/solder the amount of header pins that are being used on the chip?
2 on the bottom left and 8 on the right?
Or shold I just solder them all, incase I need to use more pins later?
Please advise, thanks.
Yes, the header pins look like this:
The short sides of the pins protrude through the through-holes on the board (like in the picture you posted earlier) and should be soldered to the surrounding pads on the top side of the PCB if you want to be able to plug it into a breadboard. If you do not have much soldering experience, I strongly suggest you find a tutorial on soldering and familiarize yourself with it before you start so you know how to apply the solder, how much solder to add, what a good solder joint looks like, etc. Otherwise, you might damage the board or create bad solder joints that don’t make adequate electrical connections.
Specifically, you should at least solder the places circled in the picture below:
I recommend you solder header pins in all the holes while you’re at it, but this isn’t absolutely necessary. The crucial part is soldering the pins you are using to the board. If you solder all the pins, it makes it easier to make alternate connections later (i.e. you won’t have to go looking for soldering iron again).
Also, this might sound obvious, but just in case it isn’t: you should not solder the board while power is being applied. In general, make sure you are really paranoid about applying power with incorrect connections as putting the wrong voltages on pins or shorting outputs together can permanently destroy electronics.
Ben this is exactly the information i was looking for - thanks so much!
I’ll get soldering tonight after ive had a bunch of beer and put my tinfoil gloves on :wink: Jokes
I am super paranoid about messing this up, hence all my questions.
Thanks again.
Ill get on this either tonight or tomorrow and get back to you.
Ok guys, working so-so here
The Stepper Motor, rotates about a1/4 the way around > pauses for 1 second > repeats
Variation i just did was to comment out the delay, and set the speed to (1)
Next step (no pun) How would I wire and code the Potentiometer?
With following Sketch
// Stepper
#include <Stepper.h>
// steps value is 360 / degree angle of motor
#define STEPS 200
// create a object on pins 6 and 7
Stepper stepper(STEPS, 6,7);
///// Turn the stepper 200 steps with a 1 sec delay between steps at 60rpm
/// then reverse the direction and do 50 steps at 20rpm with a 1sec delay between steps
stepper.setSpeed(1);
stepper.step(200);
//delay(1000);
//stepper.setSpeed(20);
//stepper.step(-50);
//delay(1000);
It looks like you are still using the stepper library that I mentioned has little chance of working. Can you confirm that this is the stepper library you are using? http://www.arduino.cc/en/Tutorial/Stepper I looked at the code for this stepper library and confirmed that it will not work with our driver.
For the potentiometer, you would connect two ends of the pot between 5V and GND of your Arduino and then connect the wiper to one of the Arduino’s analog inputs. Then you can use analogRead to read the wiper voltage. Feel free to post your circuit before you power it.
- Ryan
Hi there, yes that is the Stepper Library I am using.
So are you saying that, with that library, the POT wont work? Currently with that library installed I am able to control the Steps and RPM of the motor.
Should I comment that include line out?
Here is my illustration for the POT wiring - will it be ok to run the wire from the POT to the same 5V pin on the Arduino as the Driver board?
I dont see anywhere else to ruin it too
I just noticed that my Stepper Motor was extremely HOT to the touch
I am using a 12v 3.6Ah/C20 Lead Acid battery
I then plugged in a regular off the shelf 9v battery, ran the sketch and the Motor gave off a high pitched squeal - but still ran fine.
Should I be concerned with this?
The motor I am using is
Stepper Motor: Unipolar/Bipolar, 200 Steps/Rev, 42x48mm, 4V, 1200mA
Here is a zoomed area of the POT wired to the Breadboard for your review.
No, it has nothing to do with the pot. That stepper motor driver library is designed to work with systems where the two wires control which coils are currently energized. Your two wire interface is step and direction. That it is working at all is pretty much just a coincidence.
I recommend you use the simple sketch Ben and I suggested earlier in this thread and stop using that library. Does your stepper motor still get hot after using the other code?
Assuming you are right about which pin the wiper is on your pot, your potentiometer wiring looks correct.
- Ryan
Thanks again Ryan, im not sure about the heat of the Motor untill do the below:
SO before I upload the code
KNowing that I am using pins 6, and 7 on the Arduino, And Step and Dir on the a4398. How do i modify the Sketch and the wiring to run the below skecth? (specifically the enable pin???)
#define stepPin 2
#define dirPin 3
#define enablePin 4
int j;
You already modified the code to work with your setup. Have you tried it since you did the soldering?
- Ryan
Youre right, i did - my bad.
Ok all wired and soldered here, everything is working fine
I just couldnt find the EN pin on the a4983, but did.
Now for the POT.
I have wired just like my last graphic shows (the zoomed version).
I am currently running
#define stepPin 7
#define dirPin 6
#define enablePin 5
  int j;
Whats next? The Pot Sketch?
