Activating SPI
Hello everyone,
I’m trying to activate SPI communication on the wixel to have it talk with a Raspberry Pi. In my code I’m using the headers
#include <wixel.h>
#include <usb.h>
#include <usb_com.h>
#include <stdio.h>
#include <spi0_master.h>[/code]
My main statement is simply
[code]void main()
    systemInit();
    usbInit();
   spi0MasterInit();
    while(1) //while loop constantly executing
    	frequentTasks();
    	updateLeds();
For now I’m just trying to initialize SPI with MOSI and MISO shorted so I’d be able to at least know its working. However, when I compile my code i get an error [quote]?ASlink-Warning-Undefined Global ‘_spi0MasterInit’ referenced by module ‘example_blink_led’[/quote]
What does this even mean? I tried looking through the spi0master header but everything seems to be fine. When i add more spi0 lines to my code, they each get a new [quote]?ASlink-Warning-Undefined Global ‘_spi0MasterInit’ referenced by module ‘example_blink_led’[/quote] error.
Am I just missing or overlooking something?
Thank You.
It looks like the linker cannot find the spi_master.lib library when it tries to compile the app. As the SDK documentation mentions, if your app doesn’t use the default set of libraries defined in libraries/libs.mk, you will have to specify which libraries your app uses by creating a file called options.mk in your app directory. You can read more about this under the “Creating Your Own App” section in the SDK.
- Jeremy
Alright, got the compiling to work, now to creatively use SPI…
Much obliged Jeremy.
