Hi There,
I have installed the Atmel studio 6, and my programmer. I installed the Pololu 3pi examples. I am getting a main.c not found error. I have hacked at this for some time, and I am not making any progress.
Could use some help…
Here is what I am doing
Atmel studio 6 - choose a new project
I select the 3pi Robot with ATmega32p
It loads some sample code into the window. Code looks good.
I then choose Build Solution
I get the following errors
Build Failed
no input files
…/./main.c: No such file or directory
Here is the OUTPUT data
------ Build started: Project: 3pi_app8, Configuration: Debug AVR ------
Build started.
Project “3pi_app8.cproj” (default targets):
Target “PreBuildEvent” skipped, due to false condition; (’$(PreBuildEvent)’!=’’) was evaluated as (’’!=’’).
Target “CoreBuild” in file “C:\Program Files (x86)\Atmel\Atmel Studio 6.2\Vs\Compiler.targets” from project “\psf\Home\Documents\Atmel Studio\6.2\3pi_app8\3pi_app8\3pi_app8.cproj” (target “Build” depends on it):
Task “RunCompilerTask"
Shell Utils Path C:\Program Files (x86)\Atmel\Atmel Studio 6.2\shellUtils
C:\Program Files (x86)\Atmel\Atmel Studio 6.2\shellUtils\make.exe all
’\psf\Home\Documents\Atmel Studio\6.2\3pi_app8\3pi_app8\Debug’
CMD.EXE was started with the above path as the current directory.
UNC paths are not supported. Defaulting to Windows directory.
Building file: …/./main.c
Invoking: AVR/GNU C Compiler : 4.8.1
“C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.1061\avr8-gnu-toolchain\bin\avr-gcc.exe” -x c -funsigned-char -funsigned-bitfields -Os -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega328p -c -std=gnu99 -MD -MP -MF “main.d” -MT"main.d” -MT"main.o" -o “main.o” "…/./main.c"
avr-gcc.exe(0,0): error: …/./main.c: No such file or directory
avr-gcc.exe(0,0): warning: ‘-x c’ after last input file has no effect
avr-gcc.exe(0,0): error: no input files
compilation terminated.
make: *** [main.o] Error 1
The command exited with code 2.
Done executing task “RunCompilerTask” – FAILED.
Done building target “CoreBuild” in project “3pi_app8.cproj” – FAILED.
Done building project “3pi_app8.cproj” – FAILED.
Build FAILED.
========== Build: 0 succeeded or up-to-date, 1 failed, 0 skipped ==========
