->> Hello, I have worked with the 3pi robot some time , and was using the Arduino program to program it, and remember it was not one of the newer versions , and one day the program crashed, could not use it anymore, then I installed a newer version and since then could not use it , the 3pi code remained the same , and since then has already two months or so, sending the same code , only with PID improvements ( competed with him in a local competition, I won ), to make the calibration of the sensors everything happens naturally and the bar graph correctly shows the working sensors, but when push to start , the robot does not follow the line (white on the case , has always been, and with black background ) , time walks with it, time is in black wandering randomly . Now as part of the tests by Arduino is rather hard to configure to use the 3pi , I am using atmel studio , and yet the error persists. Thank you.
arduino code
// The following libraries will be needed by this demo
#include <Pololu3pi.h>
#include <PololuQTRSensors.h>
#include <OrangutanMotors.h>
#include <OrangutanAnalog.h>
#include <OrangutanLEDs.h>
#include <OrangutanLCD.h>
#include <OrangutanPushbuttons.h>
#include <OrangutanBuzzer.h>
#include <millis.h>
Pololu3pi robot;
unsigned int sensors[5]; // an array to hold sensor values
unsigned int last_proportional = 0;
long integral = 0;
int inicial, tempo, tempovolta;
// This include file allows data to be stored in program space. The
// ATmega168 has 16k of program space compared to 1k of RAM, so large
// pieces of static data should be stored in program space.
#include <avr/pgmspace.h>
// Introductory messages. The "PROGMEM" identifier causes the data to
// go into program space.
const char welcome_line1[] PROGMEM = " Pololu";
const char welcome_line2[] PROGMEM = "3\xf7 Robot";
const char demo_name_line1[] PROGMEM = "PID Line";
const char demo_name_line2[] PROGMEM = "follower";
// A couple of simple tunes, stored in program space.
const char welcome[] PROGMEM = ">g32>>c32";
const char go[] PROGMEM = "L16 cdegreg4";
// Data for generating the characters used in load_custom_characters
// and display_readings. By reading levels[] starting at various
// offsets, we can generate all of the 7 extra characters needed for a
// bargraph. This is also stored in program space.
const char levels[] PROGMEM = {
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b00000,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111,
0b11111
// This function loads custom characters into the LCD. Up to 8
// characters can be loaded; we use them for 7 levels of a bar graph.
void load_custom_characters()
OrangutanLCD::loadCustomCharacter(levels + 0, 0); // no offset, e.g. one bar
OrangutanLCD::loadCustomCharacter(levels + 1, 1); // two bars
OrangutanLCD::loadCustomCharacter(levels + 2, 2); // etc...
OrangutanLCD::loadCustomCharacter(levels + 3, 3);
OrangutanLCD::loadCustomCharacter(levels + 4, 4);
OrangutanLCD::loadCustomCharacter(levels + 5, 5);
OrangutanLCD::loadCustomCharacter(levels + 6, 6);
OrangutanLCD::clear(); // the LCD must be cleared for the characters to take effect
// This function displays the sensor readings using a bar graph.
void display_readings(const unsigned int *calibrated_values)
unsigned char i;
for (i=0;i<5;i++) {
// Initialize the array of characters that we will use for the
// graph. Using the space, an extra copy of the one-bar
// character, and character 255 (a full black box), we get 10
// characters in the array.
const char display_characters[10] = { ' ', 0, 0, 1, 2, 3, 4, 5, 6, 255 };
// The variable c will have values from 0 to 9, since
// calibrated values are in the range of 0 to 1000, and
// 1000/101 is 9 with integer math.
char c = display_characters[calibrated_values[i] / 101];
// Display the bar graph character.
OrangutanLCD::print(c);
// Initializes the 3pi, displays a welcome message, calibrates, and
// plays the initial music. This function is automatically called
// by the Arduino framework at the start of program execution.
unsigned int counter; // used as a simple timer
// This must be called at the beginning of 3pi code, to set up the
// sensors. We use a value of 2000 for the timeout, which
// corresponds to 2000*0.4 us = 0.8 ms on our 20 MHz processor.
robot.init(2000);
load_custom_characters(); // load the custom characters
// Play welcome music and display a message
OrangutanLCD::printFromProgramSpace(welcome_line1);
OrangutanLCD::gotoXY(0, 1);
OrangutanLCD::printFromProgramSpace(welcome_line2);
OrangutanBuzzer::playFromProgramSpace(welcome);
delay(1000);
OrangutanLCD::printFromProgramSpace(demo_name_line1);
OrangutanLCD::printFromProgramSpace(demo_name_line2);
delay(1000);
// Display battery voltage and wait for button press
while (!OrangutanPushbuttons::isPressed(BUTTON_B))
int bat = OrangutanAnalog::readBatteryMillivolts();
OrangutanLCD::print(bat);
OrangutanLCD::print("mV");
OrangutanLCD::print("Press B");
delay(100);
// Always wait for the button to be released so that 3pi doesn't
// start moving until your hand is away from it.
OrangutanPushbuttons::waitForRelease(BUTTON_B);
delay(1000);
// Auto-calibration: turn right and left while calibrating the
// sensors.
for (counter=0; counter<80; counter++)
if (counter < 20 || counter >= 60)
OrangutanMotors::setSpeeds(40, -40);
OrangutanMotors::setSpeeds(-40, 40);
// This function records a set of sensor readings and keeps
// track of the minimum and maximum values encountered. The
// IR_EMITTERS_ON argument means that the IR LEDs will be
// turned on during the reading, which is usually what you
// want.
robot.calibrateLineSensors(IR_EMITTERS_ON);
// Since our counter runs to 80, the total delay will be
// 80*20 = 1600 ms.
delay(20);
OrangutanMotors::setSpeeds(0, 0);
// Display calibrated values as a bar graph.
// Read the sensor values and get the position measurement.
unsigned int position = robot.readLine(sensors, IR_EMITTERS_ON);
// Display the position measurement, which will go from 0
// (when the leftmost sensor is over the line) to 4000 (when
// the rightmost sensor is over the line) on the 3pi, along
// with a bar graph of the sensor readings. This allows you
// to make sure the robot is ready to go.
OrangutanLCD::print(position);
display_readings(sensors);
delay(100);
OrangutanLCD::print("Go!");
OrangutanLCD::print("INABULL2");
// Play music and wait for it to finish before we start driving.
OrangutanBuzzer::playFromProgramSpace(go);
while(OrangutanBuzzer::isPlaying());
inicial=millis();
// The main function. This function is repeatedly called by
// the Arduino framework.
tempo = millis();
tempovolta = tempo-inicial;
// Get the position of the line. Note that we *must* provide
// the "sensors" argument to read_line() here, even though we
// are not interested in the individual sensor readings.
// The "proportional" term should be 0 when we are on the line.
int proportional = (int)position - 2000;
// Compute the derivative (change) and integral (sum) of the
// position.
int derivative = proportional - last_proportional;
integral += proportional;
// Remember the last position.
last_proportional = proportional;
// Compute the difference between the two motor power settings,
// m1 - m2. If this is a positive number the robot will turn
// to the right. If it is a negative number, the robot will
// turn to the left, and the magnitude of the number determines
// the sharpness of the turn. You can adjust the constants by which
// the proportional, integral, and derivative terms are multiplied to
// improve performance.
int power_difference = proportional/7 + derivative*4;
// int power_difference = proportional/20 + integral/10000 + derivative*3/7 p 100 lento demais
// proportional/7 + derivative*4 p 220 time_lap = 9.5s
// proportional/20 + integral/10000 + derivative*10 p 250 time_lap = 9.3s
// proportional/10 + integral/20000 + derivative*6 p 250 time_lap = 8.1s
// proportional/10 + integral/20000 + derivative*7 p 250 time_lap = 8.0s
// proportional/10 + integral/20000 + derivative*8 p 250 time_lap = 8.0s
// proportional/10 + integral/30000 + derivative*9 p 250 time_lap = 8.1s
// Compute the actual motor settings. We never set either motor
// to a negative value.
const int maximum = 220;
if (power_difference > maximum)
power_difference = maximum;
if (power_difference < -maximum)
power_difference = -maximum;
if (power_difference < 0)
OrangutanMotors::setSpeeds(maximum + power_difference, maximum);
OrangutanMotors::setSpeeds(maximum, maximum - power_difference);
//while( tempovolta >= 10000){
//OrangutanMotors::setSpeeds(0, 0);
