Is someone knows if zumo can function with a ATMEGA 2560 arduino card ? With the blade, it’s clear that the card is unpluggable, but is there some electronic hardware issues between zumo and and this card ?
Many thanks by advance
It should be possible to use an Arduino Mega with the Zumo shield. However, as you mentioned, the blade will interfere with the board. Some people have used extended headers, like the female header set for Arduino shield, to clear the blade. Alternatively, you could remove or modify the blade.
- Jeremy
