Controlling a Zumo Robot with a Joystick Shield
The ElecFreaks.com Joystick shield can be combined with a nRF24L01+ wireless transceiver.
If the Zumo Robot is extended with such an nRF24L01+ transceiver module, the Zumo bot is controllable with a joystick. Great fun to drive the robot with a joystick around. The nRF24L01+ transceiver is sensitive to voltage drops, and this article explains the problems and as well the solution:
mcuoneclipse.com/2014/05/16/joys … umo-robot/
Happy Driving :slight_smile:
Thank you for sharing; its cool that you were able to reduce the noise from the 3.3V supply enough in your current design to get a workable system. I hope the new board takes care of the issue entirely!
- Amanda
Hi Amanda,
yes, the new board works now without issues. We added more capacitance to buffer the power supply, and now everything works with full speed back and forward :slight_smile:
Erich
