I am sorry you are having problems programming your 3pi. It sounds like the 3pi was not powered during programming. If powering it on does not help, could you try replacing the batteries? If you still have problems, could you tell me more about your setup? Are you using AVRDUDE through a terminal program or are you using a piece of software that runs AVRDUDE?
batteries are not … I charge them and medi … but normally use arduino tanbien try from cmd and also with avrdude wizard, but still the same I think the micro damage
I still suspect the device is not being powered correctly when you are trying to program it. Could you try measuring across Vcc and GND of the 3pi and programmer with a voltmeter to see if they are getting powered correctly when programming?
