Note: Do not use any of the Pololu AVR library’s line sensor functions while your distance sensor is connected to PC5. Even with the PC5 jumper disconnected, the library’s line sensor routines will attempt to control the emitters by driving PC5 high for the duration of the sensor read and then driving PC5 low. You want PC5 to remain an input for duration of the time it is connected to your sensor.
pololu_3pi_init_disable_emitter_pin(unsigned int line_sensor_timeout)Users browsing this forum: No registered users and 1 guest
My Account
Wish Lists
BIG Order Form
Shopping Cart
1-702-262-6648 |
