cant program
The place to discuss the Pololu 3pi robot and share your code.
cant program
Postby karandex on Thu Mar 18, 2010 4:17 am
i got a programmer
http://www.nskelectronics.in/avr_dude.html
i made a 10 pin to 6 pin converter
then the programmer does not work with avr studio
i tried the software called sinaprog hex downloader with provided disc
but it is not programming
does 3pi turn on when i connect to programmer but without blue led and when it fails to program then it resets
Please help
karandex
Re: cant program
Postby jan on Thu Mar 18, 2010 9:05 am
Have you verified that your programmer and adapter work by programming some other AVR? To program the 3pi, you must have it turned on, in which case the blue LEDs should be on. If the LEDs go out when you attach the programmer or during programming, there is something very wrong with your programmer or adapter. Is that what is happening?
- Jan
User avatar
jan
Site Admin
Re: cant program
Postby karandex on Thu Mar 18, 2010 10:00 am
if i turn o 3pi first then the light remain on, but if i connect programmer first then 3pi turn on without blue leds
i am using a usbasp programmer which dont have support of 328p
is that the reason or my 10 pin to 6 pin board is wrong ?
how can i program it with arduino becaus the guide show the atmega168
what should be change in line to be added to board.txt
karandex
Re: cant program
Postby karandex on Thu Mar 18, 2010 11:00 am
i think the problem is that programeer is usbasp programmer
please see the powering isuue
do i stricltly need usb programmer can i use serial prgrammer
my usb programmer is providing power after building 10 pin to 6 pin converter ( only 3pi not blue led)
as said in previous post
Do i need avrisp programmer strictly
karandex
Re: cant program
Postby karandex on Thu Mar 18, 2010 11:40 am
now i have removed the vtg pin to 6 pin of 3pi now it does not power by 3pi but still with sinaprog i cannot program the 3pi
there is no other software for usbasp that support atmega328 p
please suggest if u know any
karandex
Re: cant program
Postby jan on Thu Mar 18, 2010 12:16 pm
The programmer keeping the 3pi from turning on sounds really bad, and you might be damaging the 3pi or programmer hardware. Also, if the programmer is known not to support the AVR you're trying to program, it sounds like you should be looking for a different programmer (or bugging the manufacturer to update the programmer). You don't have to have an AVRISP from Atmel, but it should be a programmer capable of programming the chip you're using over the physical connection you have. It will also be more convenient if the programmer is supported by whatever development environment you're using.
- Jan
User avatar
jan
Site Admin
Re: cant program
Postby karandex on Thu Mar 18, 2010 12:53 pm
have u checked the link above
please check my programmer
i think the trouble is wth programmer
i have disconnected the vdd coming from programmer so 3 pi dosent turn on now.
please check it and tell me
i have other alternatvies for programmer please have a look and suggest me one
again can i use serial programmer ?
can i compile in avrstudio and burn it by using other software,
one of thprogrammer from following list is a programmer with 5 pins
how these pins are setup
http://www.nex-robotics.com/products/mi ... ammer.html
http://www.technophilia.co.in/product_d ... duct_id=67
please see and help me
karandex
Re: cant program
Postby jan on Thu Mar 18, 2010 1:48 pm
What do you want me to look at? You said the programmer doesn't support the AVR you're using, so what do you expect me to find? I already addressed your other questions in my previous post: you need a programmer that you can connect to your computer, that can program the AVR you're using over the connection you have (ATmega328P with the 6-pin ISP connection in the case of the 3pi), and that will work with your software. It's possible to compile in one environment and to use another program for programming; it just might not be that convenient.
Regarding the other programmers, you should contact the respective manufacturers of those units.
- Jan
User avatar
jan
Site Admin
Re: cant program
Postby Ben on Thu Mar 18, 2010 5:02 pm
If you need help getting your programmer working, you really need to contact the manufacturer of your programmer for help. When programming the 3pi, you should not use a programmer that delivers power to the target device. You might consider using our AVR programmer.
- Ben
User avatar
Ben
Site Admin
Re: cant program
Postby karandex on Thu Mar 18, 2010 6:41 pm
the problem is with programmer, even with provided sinaprog software which contains avrdude entry for 328 ( in . confg) file it even dosent recognize the programmer though the drivers are installed properly.
Can i use serial programmer ?
karandex
Re: cant program
Postby Ben on Thu Mar 18, 2010 10:13 pm
You have direct access to the ATmega328p AVR on the 3pi, so you can program the 3pi with anything capable of programming an ATmega328p.
User avatar
Ben
Site Admin
Re: cant program
Postby karandex on Fri Mar 19, 2010 2:32 am
in my programmer there is exchange of miso and mosi
but now right wheel zoom for moment programming fails
with error
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
karandex
Re: cant program
Postby karandex on Fri Mar 19, 2010 4:40 am
i think problem is with fuse bits , because the program sinaprog have a txt called fuse and in which there are fuse bits only for atmega 8 , 16 , 32
is my uc is damaged ?
when i try to program right motor moves a bit.
I live in india and i got it from sparkfun, can u replace it ?
karandex
Re: cant program
Postby karandex on Fri Mar 19, 2010 5:19 am
some more info
First of all i HAVE to use sinaprog to load hex
in fuse.txt there are files for atmega 8 , 16 ,32 because board came with it was only to be used with those chips
Default.
ATmega8.ATmega16.
[Int. 1 MHz d9e1
Int. 2 MHz d9e2
Int. 4 MHz d9e3
Int. 8 MHz d9e4
Ext. Crys. d9ff]
ATmega32.
[Int. 1 MHz d9e1
Int. 2 MHz d9e2
Int. 4 MHz d9e3
Int. 8 MHz d9e4
Ext. Crys. d9ff]
please suggests similar to atmega 328p
Please help i am very much in trouble
If some one like ben can send his mail to chat that will be great
karandex
Re: cant program
Postby karandex on Fri Mar 19, 2010 6:29 am
Every thing is working now
it was problem with vcc wire
But it is very slow, its take about 1-2 min.
why ?
karandex
Next
Return to 3pi Robot
Who is online
Users browsing this forum: No registered users and 1 guest
