Greetings POLOLU COMMUNITY,
My enquiry is for your guidance, formatting or example with my project:
PROJECT:
Adobe Flash AS3 UI sending TTL via AS3 Socket Class to a Virtual Com Port assigned to a Pololu Maestro Servo Controller.
PROJECT GOAL:
- Simulate a RC Radio Transmitter with a Adobe Flash UI in .SWF Format.
- AS3 UI for RC Servo Controllers & Robotics.
PROJECT FORMAT:
a. The Adobe Flash AS3 RC_Transmitter_UI.swf will:
- Graphically represent the Sticks & Knobs seen on “RC Radio Transmitters”
- Interpret the X & Y Coordinates of the UI Sticks
- Interpret the Value of UI Knobs or Pots
- Assign these values to Declarations as “Channels”, example “9 channel RC Transmitter”
- Send these Declarations as “TTL” via AS3 Socket Class
- I/O via AS3 Socket Class the “TTL” to a Pololu Software Virtual Com Port
- Resulting control of the Pololu Maestro Servo Controller.
- Thereafter you control your RC Robot or Airplane with Adobe Flash
PROJECT HARDWARE:
TouchScreen PC:
a. The TouchScreen PC will input 2 Mouse Pointers controlling the RC_Transmitter_ UI.swf & simulating the RC Radio Transmitter Sticks.
b. Reference the Microsoft Multi-Point Mouse SDK:
c. microsoft.com/multipoint/mou … wcase.aspx -
Servo Controller & Software:
a. Pololu Maestro Servo Controller & Software including Virtual Com Ports.
b. The Pololu Maestro Control Center Software:
c. Installs Pololu Virtual Com Ports in the Device Manager
d. Command Port
e. TTL Port
f. Controls the Servos
g. Script Editor
PROJECT REFERENCE:
Reference URL Pololu Maestro Servo Controller:
a. pololu.com/product/1354/resources -
Reference URL Pololu Maestro Servo Controller Software with Virtual Com Ports:
a. pololu.com/file/0J266/maestr … 130422.zip -
Reference URL Microsoft Multi Mouse with Adobe Flash:
a. microsoft.com/multipoint/mou … wcase.aspx
PROJECT REQUEST:
5. My enquiry with the Pololu Community is for AS3 formating & compiling:
a. Construct the Flash UI for the RC Transmitter:
b. STICKS:
c. adobe.com/devnet/actionscrip … ing_1.html
a. SLIDERS:
b. adobe.com/devnet/actionscrip … ity_2.html
a. AS3 NETWORK THE POLOLU VIRTUAL COM PORT:
b. help.adobe.com/en_US/FlashPlatfo … ocket.html
PROJECT REFFERAL:
4. If you have opportunity,
a. review Adobe Flash AS3 Socket Class & how to network with the Pololu Virtual Com Ports & the Pololu Maestro Servo Controller.
b. review Microsoft Multi-Mouse SDK including examples of Educational Adobe Flash UI utilizing Multiple Mouse & enquire as to formating for a RC_Transmitter_UI.swf.
I suggest this project is useful for the entire Pololu Community. The ability to control Pololu Components with Adobe Flash AS3 & the AS3 Socket Class.
Respond with any suggestion, option or formating.
Thank You & have a good day,
Garrett Min
