Arduino Servo NewSoftSerial
Support for Pololu RC servo controllers.
Postby conor on Thu Oct 29, 2009 12:39 pm
Hi
I've been working on a project that controls 6 servos with the Polulu 8 servo controller. I'm syncing the movement of my servos to each frame of a quicktime (25 fps) Using Max/msp. After much head scratching I've got it working with 3 servos, but now that I've got 6 running, the servos aren't keeping up. I'm using the old SoftwareSerial library that can only run at 9600 baud. I've tried using the NewSoftwareSerial library (which can run at much higher baud rate) but I just get a red and green flashing light. Has anyone used the NewSoftwareSerial library? or could there be another reason for the problem? (I've included my code)
Any pointers would be greatly appreciated ( I'm afraid I'm still struggling with Arduino).
Kind regards Conor
Code: Select all
// Pololu micro serial servo controller modes
// Software Serial from Arduino example by Tom Igoe
// put() (now position_absolute) & set_speed() functions found on pololu forums & modified
// mike crist 2009-01-03
#include <SoftwareSerial.h>
#define rxPin 2
#define txPin 3
// set up a new serial port
SoftwareSerial softSerial =  SoftwareSerial(rxPin, txPin);
int i = 500;
void setup()
  pinMode(rxPin, INPUT);
  digitalWrite(txPin, HIGH); // keeps pololu board from getting spurious signal
  pinMode(txPin, OUTPUT);
  // set the data rate for the hardware serial port
  Serial.begin(9600);
  // set the data rate for the SoftwareSerial port
  softSerial.begin(9600);
  set_speed(0, 0);
  set_speed(1, 0);
  set_speed(2, 0);
  set_speed(3, 0);
  set_speed(4, 0);
  set_speed(5, 0);
void loop()
Serial.flush();
  char inputA[8];
  char inputB[8];
  char inputC[8];
  char inputD[8];
  char inputE[8];
  char inputF[8];
  memset(inputA, '\0', 8);
  memset(inputB, '\0', 8);
  memset(inputC, '\0', 8);
   memset(inputD, '\0', 8);
  memset(inputE, '\0', 8);
  memset(inputF, '\0', 8);
  byte inByte = '\0';
  while(inByte != 'A') {
    inByte = Serial.read(); // Wait for the start of the message
  if(inByte == 'A') {
    while(Serial.available() < 24) { // Wait until we receive 5 characters
    for (int a=0; a < 24; a++) {
      if( a >= 0 && a <= 3){
      inputA[a] = Serial.read(); // Read the characters into an array
  if( a >= 4 && a <= 7){
      inputB[(a-4)] = Serial.read(); // Read the characters into an array
   if( a >= 8 && a <= 11){
      inputC[(a-8)] = Serial.read(); // Read the characters into an array
  if( a >= 12 && a <= 15){
      inputD[(a-12)] = Serial.read(); // Read the characters into an array
  if( a >= 16 && a <= 19){
      inputE[(a-16)] = Serial.read(); // Read the characters into an array
  if( a >= 20 && a <= 23){
      inputF[(a-20)] = Serial.read(); // Read the characters into an array
  int  numberA = atoi(inputA);
   int  numberB = atoi(inputB);
    int  numberC = atoi(inputC);
    int  numberD = atoi(inputD);
   int  numberE = atoi(inputE);
    int  numberF = atoi(inputF);
position_absolute(0, numberA);
position_absolute(1, numberB);
position_absolute(2, numberC);
position_absolute(3, numberD);
position_absolute(4, numberE);
position_absolute(5, numberF);
void position_absolute(byte servo, int angle)
  //this function uses pololu mode command 4 to set absolute position
  //servo is the servo number (typically 0-7)
  //angle is the absolute position from 500 to 5500
   unsigned int temp;
   byte pos_hi,pos_low;
   temp = angle & 0x1f80;  //get bits 8 thru 13 of position
   pos_hi = temp >> 7;     //shift bits 8 thru 13 by 7
   pos_low = angle & 0x7f; //get lower 7 bits of position
   //Send a Pololu Protocol command
   softSerial.print(0x80, BYTE);    //start byte
   softSerial.print(0x01, BYTE);    //device id
   softSerial.print(0x04, BYTE);    //command number
   softSerial.print(servo, BYTE);   //servo number
   softSerial.print(pos_hi, BYTE);  //bits 8 thru 13
   softSerial.print(pos_low, BYTE); //bottom 7 bits
void set_speed(byte servo, byte speedVal)
   //this function uses pololu mode command 1 to set speed
   //speedVal is servo speed (1=slowest, 127=fastest, 0=full)
   //set speedVal to zero to turn off speed limiting
   speedVal = speedVal & 0x7f; //take only lower 7 bits of the speed
   softSerial.print(0x80,BYTE);     //start byte
   softSerial.print(0x01,BYTE);     //device id
   softSerial.print(0x01,BYTE);     //command number
   softSerial.print(servo,BYTE);    //servo number
   softSerial.print(speedVal,BYTE); //speed
conor
Re: Arduino Servo NewSoftSerial
Postby DavidEGrayson on Fri Oct 30, 2009 11:50 am
Are there any devices on those two software serial lines besides the Arduino and the Pololu servo controller? -David
DavidEGrayson
Site Admin
Postby conor on Fri Oct 30, 2009 11:56 am
Hi
No, just the arduino, servo controller and my computer.
Conor
conor
Postby conor on Tue Nov 03, 2009 12:46 pm
Hi
I thought I would include the code I've been using with the NewSoftSerial, as soon as I replaced my old code with this I got the red light and flashing green. Can anyone help it's driving me mad.
Regards Conor
Code: Select all
#include <NewSoftSerial.h>
NewSoftSerial softSerial(2, 3);
void setup()
  //pinMode(2, INPUT);
  digitalWrite(3, HIGH); // keeps pololu board from getting spurious signal
  pinMode(3, OUTPUT);
  Serial.begin(9600);
  set_speed(0, 0);
  set_speed(1, 0);
  set_speed(2, 0);
  set_speed(3, 0);
  set_speed(4, 0);
  set_speed(5, 0);
void loop()
  Serial.flush();
  char inputA[8];
  char inputB[8];
  char inputC[8];
  char inputD[8];
  char inputE[8];
  char inputF[8];
  byte inByte = '\0';
  if(inByte == 'A') {
    while(Serial.available() < 24) { // Wait until we receive 12 characters
  unsigned int temp;
conor
Postby RyanTM on Tue Nov 03, 2009 12:49 pm
Hi conor,
It helps a lot if you wrap your code with [code] tags. It's easy to do: highlight your code in the post text editor and click the code button above the editor.
- Ryan
User avatar
RyanTM
Postby conor on Tue Nov 03, 2009 12:52 pm
Thanks Ryan I'll remember that in future.
Cheers Conor
conor
Return to Pololu Servo Controllers
Who is online
Users browsing this forum: No registered users and 1 guest
