I want to make sure im doinf everything right. Here is a pic showing how to wire the wireless RX to tje arduino. I see that the maestro 24 comes with a 5v out can this be used to power the arduino.
I have no idea how this would hook up the pololu, using the pic above do i still have the needed pins to wire it to a meastro?
I got my maestro-24 yesterday and finally got around to doing some reading. Looks like this is a very versatile system here able to do alot more than any other all-in-1 servo controller.
I was thinking maybe they could add an inverse/forward kinematics solver to the program that way even a hobbyist like me could make thier robots have more life-like movements. I would even be inclined to pay gor such an add on.
Just an idea.
Will have questiins soon. Fixing to hook it up to my Hex.
Been playing today. Last night i entered my numbers into the sequencer for a ripple gait which didnt work at first. I blew two Coxa servos and had 2 plugged in wrong. Got up today and it walked just fine.
Also read up on the 5v out and soldered a couple servo leads to one and used it to power my arduino and the arduino powers the wireless PS2 RX. Thats pretty cool but ill need a Higher MaH battery. Its gonna suck my 3s 500mah down quicker.
I recommend looking at the “Basic” and “Script” examples included in the Pololu Maestro Arduino library to see how to write code for the Arduino that will trigger actions on the Maestro. There is a great deal of flexibility with the way something can be implemented between the two platforms. In general, for more complicated projects like this, I recommend starting with the examples to understand how the functions work, writing pieces of simplified code that do parts of the functionality you want in your project, and then integrating these simplified pieces together to get more complex behavior.
Ok i have been looking at the script examples for pololu and looking at the Maestro\arduino library and im still very confused. What it looks like to me is that its telling you how to make and run subroutine using the arduino. Though i still dont see how its activating the subroutine.
I need to know how to activate a prewritten subroutine.
One thing that would help is knowing and understanding the signals that are passed back and fourth from the arduino to the maestro. I think. I really dont know because i dont understand this stuff. Wish more was written in laymens.
Looking at the PS2X_lib.H file there are numbers after each button written like this X button 0x1000. Im assuming this is is the Arduinos serial output when X is pressed.
If so how do i convert this number to a number that the Pololu will understand when the signal is sent?
If you look at the “Script” example from the Pololu Maestro Arduino library, lines 30 to 51 contain code that is meant to go into the “Script” portion of the Maestro Control Center software and be uploaded to the Maestro. This code contains two different prewritten subroutines (which in these cases are sequences of servo movements that have been put into the script). The execution of the script on the Maestro is controlled by the statements on lines 87, 91, and 99.
The Maestro and the Arduino communicate with each other over TTL Serial. Essentially, the Arduino sends a sequence of digital bits over the line connected to the Maestro when the statements noted above (lines 87, 91, and 99) are executed.
In general, you will probably want to write code for the Arduino that looks at the state of your PS2 controller and if one of the buttons is pressed, executes the maestro.restartScript(i); command, which will send the appropriate serial command from the Arduino to the Maestro.
Ive got a 24 step Ripple sequence ive been using but im not too happy with. I would like to make it a 12 step. Problem is i need to make each leg raise rotate and drop in the same frame. Is there a way to do this with out it being to hard?
Also can i make a seperate script for each sequence or do they all have to be part of the same one.
Is it possible to create movements that start from the last frame executed. Say i release the button with the 3rd leg up and rotated and i push it again it starts from 3rd leg up and rotated?
Only one script can be loaded onto the Maestro at a time. Is there a reason separating your code into subroutines and calling the subroutines would not work? The last example I pointed you to shows how to call different Maestro subroutines from the Arduino.
It will probably be difficult to get the Maestro to pick up movements where it left off previously. You might be able to break your movements into smaller steps and have the Arduino call them more frequently so that if you interrupt a movement in your Arduino code, you will have a better idea of where it was interrupted.
No reason thought it might be easier to write several different sequences to keep them seperate. IDK my filing system is weird. i can still work with it.
I was actually thinking of a read call to see where the servos are then an if statement to execute from where it last read.
Can the sequencer go faster than 100ms? I noticed it would allow me to type in under 100 but didnt try to do anything with it. 100ms i know is pretty fast at 10th a second but most of the other bots i see seem to move faster.
The getPosition command in the Maestro library will return the current target position the Maestro is sending to the specified channel, so that might also help you determine where your script was stopped. Also, it might help you to know that if a movement command like 6000 0 servo is executed in a script and then the script is stopped immediately, the Maestro will continue commanding the servo to move toward this target.
To change the length of time to wait for a movement to occur for a frame in a sequence, simply double click the frame in the “Frames” portion of the “Sequence” tab, and type in a new duration in the dialog box that appears. However, you should know that this does not affect the movement speed of the servo, only the length of time the Maestro waits before beginning the next action.
For more information on how the Maestro controls servo speed, you can look at the Speed and Acceleration headings under the Channel Settings section of the Maestro user’s guide. To learn how to change the speeds on a channel as the program runs, you can look at the Set Speed and Set Acceleration headings under the Serial Servo Commands section or the Servo, LED, and other output commands table of the Command Reference section of the same user’s guide.
Finally, please note that there is some physical speed limit on the servos themselves as well and even if the Maestro is sending a faster move command, the servo will still be limited by this physical limit.
I was getting a lil ahead of myself there with “if” statements right now. I think i need to concentrate on my PS2 controller dilemma.
Ok so after doing some reading and some looking up i found out that the numbers after the buttons on the library.h for the arduino part are the byte packets sent through the serial.
My question is… If the bytes sent are in this exampl… 0x0000 and the pololu needs commands like this example 0x00. Do i need to set the byte packets sent the latter protocol or will the Pololu automatically understand the command.
Ok the first byte sent should be the Baud rate in Pololou protocol?
In my PS2 handle code it sets the serial baud rate to 57600, does this number need to be changed to pololu command protocol or does it always have to recieve 0xAA
If you look at the “Script” example from the Pololu Maestro Arduino library, lines 30 to 51 contain code that is meant to go into the “Script” portion of the Maestro Control Center software and be uploaded to the Maestro. This code contains two different prewritten subroutines (which in these cases are sequences of servo movements that have been put into the script). They execution of the script on the Maestro is controlled by the statements on lines 87, 91, and 99.
-Nathan[/quote]
Ok you said lines 87, 89 and 99 are my activation functions, the integer in the parameters would be the subroutine im calling. Ok so do i call a serial read Function call to listen for each button press?
Ok been doing alot of reading and came up with the code im posting below. Please dont make fun of me ive never actually written my own code before so o know it might be a lil mixed up.
Basically im opening the pololu serial and telling it listen for a byte with the serial.read function. If it reads 0x0008 or the up button on the PS2 cotroller it activates subroutine 1. If it reads no signal then it stops subroutine 1.
It looks like you have the right idea of reading an input from your controller and then sending a command to start the appropriate script on the Maestro, but I would not expect that code to work. The language that the Arduino uses is C++ and it might be helpful for you to find an online tutorial or course for that. For instance, boolean comparisons like the ones you are using in your if statements in C++ require the ‘==’ operator since ‘=’ is the assignment operator (to make one thing take the value of the other).
There is documentation for the Maestro Arduino library on its GitHub page. You can click the “Classes” tab at the top to see the available objects, methods, and functions.
