I am designing something that requires different output voltages (at relatively high current) at different times. I can see the output of the U3V50ALV is controlled by a trimpot but I wondered, could the output voltage be controlled a microprocessor?
Are the detailed specs and schematics available for the U3V50ALV? I couldn’t find them on the website.
Unfortunately, we do not know of an easy way to control the output voltage of our adjustable regulators from a microcontroller. How many different voltages and what kind of transitions between them do you need?
We don’t make the schematic for that regulator available. Everything we make available about the regulator is on its product page; what detailed specs are you looking for?
Those characteristics are generally beyond what we are prepared to specify. By the way, I think some of your questions do not even make sense, at least not without a lot more discussion (e.g. output current waveform is mostly up to your load). What kind of system are you trying to power or control?
