Testing Arduino Micro
I am no longer getting blink blink as I load sketches on my Micro. The blue light and a couple of other LEDs come on, but no sign of activity beyond that.
/dev/tty.bluetooth-incoming-port <<< tried this
/dev/cu.bluetooth-incoming-port <<< tried this
/dev/tty.bluetooth-modem <<< is reported busy
/dev/cu.bluetooth-modem <<< is reported busy
I don’t see any /dev/tty.usbmodem as the instructions on Arduino site suggest should be on a Mac.
Assuming everything external to the controller is Okay, what is a good way to figure out if the controller has gone bad?
Thanks in advance.
Farzad
Hello, Farzad.
In light of your subsequent post here, it looks like this is a solved issue. If you really applied 12V to something other than the VIN pin of your Arduino Micro, then it is most likely that the board is damaged beyond repair.
- Amanda
Yes, thanks. I am getting a couple of new controllers.
You know, it would be nice to have a protection similar to what we have at the gas pump where the diesel nozzle just doesn’t fit the regular tank! I almost did that to my car recently.
Farzad
