Dual MC33926 Motor Driver Carrier
Hello. I bought a Dual MC33926 Motor Driver Carrier and do not use the truth as I do not understand yet. I would appreciate very much if I could guide you in how to connect and how to program my arduino to control a dc motor.
I have not much experience in using this type controllers.
I would like to give me a way to connect and q I have read there are several ways to connect but do not describe any. :confused: :frowning:
It sounds like our dual MC33926 motor driver shield for Arduino would be a much more appropriate product for you since the connections are automatically made for you when you plug it into the Arduino and we have sample code available. If you want to try to make it work with the driver you have now, I suggest you use our shield as a reference. If you make the same connections to your Arduino as the shield does, our Arduino library code should work for you.
- Ben
