Backlash for Gearmotor 37Dx52L mm with 64 CPR Encoder
Does anyone have data on backlash on Gearmotor 37Dx52L mm with 64 CPR Encoder
I am looking for values for all gear options.
I have purchased motor 19:1 and backlash is roughly 1 deg.
I would be interested in data for other gear options.
Regards,
Przemek
Hello, Przemek.
We do not have the backlash for those motors characterized, but we expect there to be a couple degrees of backlash on the output shaft. Also, I suspect that having more gears would increase the backlash, but I do not know if it would be a significant change from what you are seeing.
- Grant
