I think Paul wrote is response while I was writing this...Hello chelmi. I'm glad you are enjoying the jrk! The Jrk Configuration Utility does not have the ability to control two jrks simultaneously with the wiring you made above. But there are several ways you could control two jrks from a computer.
Controlling two Jrks with two USB cablesIf you want to control two Jrks from your computer, one option is to get two USB cables and connect both Jrks to the computer at the same time. Then you can run two copies of the Jrk Configuration Utility and control them that way. With this wiring, you could also put the Jrks in to "USB Dual Port" mode and use the jrk's respective Command Ports (virtual serial ports created on your computer by the Jrks) to control the Jrks. With this wiring, you get two USB-to-serial adapters in your project; i.e. you can use the Jrk's respective TTL Serial ports to communicate with some extra serial devices.
This method gives you the most control over your project because you have lots of different options for controlling the two Jrks and you get two USB-to-serial adapters for free.
Controlling two Jrks with USB Dual PortAlternatively, you can wire the system as shown in your picture above. The master jrk (the one with the USB cable) should be in "USB Dual Port" serial mode so it accepts commands from the Command Port and the slave jrk should be in "UART" serial mode so it accepts TTL serial commands. This allows you to send commands to the master Jrk using either the Jrk Configuration Utility OR the Command Port. To control the other Jrk, you would have to use the master jrk's TTL Serial Port, which acts like a USB-to-Serial adapter in dual port mode.
This method allows you to have compact installations because you don't need multiple USB cables and it lets you use the faster compact serial protocol (instead of the Pololu Protocol) because the Jrks are not on the same serial port.
Controlling two Jrks with USB Chained ModeAlternatively, you can wire the system as shown in your picture above and use USB Chained Mode. The master jrk (the one with the USB cable) should be in "USB Chained Mode" serial mode so it accepts commands from the Command Port and the slave jrk should be in "UART" serial mode so it accepts TTL serial commands. This allows you to send commands to the master Jrk using the Jrk Configuration Utility, and you can use the Command Port to send commands to both Jrks.
This method allows you to have compact installations because you don't need multiple USB cables and it gives you the simplicity of controlling both Jrks from one virtual serial port, which might make it easier to write your program.
How to use the Command Port or the TTL PortTwo of the solutions above require you to send some serial commands on a virtual serial port (either the Command Port or the TTL Port). To do this, you would have to run the
Pololu Serial Transmitter or write your own program to send and receive bytes on the port. If you want to write your own program, I recommend the freely available .NET framework and its included SerialPort class, but there are other programs like LabView and MatLab that support serial ports.
-David
