Configuration of kill switch via serial interface possible?
Hi folks,
I am developing a product using 24v12 simple motor controllers.
For an added bit of safety Iโ€™d like to use the kill switch feature on the A2 input (A1 is already used for something different).
Is there a way to activate the kill switch just using serial commands?
I know I can do this via USB, but I really donโ€™t want to configure hundreds of boards manually that way.
Any hints welcome.
Cheers,
Wolferl
There is no serial command that will configure a limit/kill switch for the Simple Motor Controller (SMC), but you can save a settings file using the Simple Motor Control Center and then apply it to each SMC. I recommend using the SmcCmd command-line utility to help automate that process.
We would be interested to hear more about your product. Please keep us posted!
Oh, too bad :frowning:
Maybe that is a suggestion for a new feature?
Thanks for your help.
Wolferl
