P*Star doesn't execute test code
Hi to everybody.
I just got a PStar, but I can’t get this working. I 've followed each step in pololu P star guide to run the assembler test code , but it doesnt run :cry: .
I’ ve installed the “p load” aplication and my computer recognize the board and every thing is OK,
i compilled the assembler test code to drive red led using MPLAB X 2.35, after compilating I download the hexfile to the board using comand p-load -w hexfile , again everiting was OK.
I got this message:
Bootloader: Pololu P-Star 25K50 Bootloader
Serial number: 00096942
Erasing flash…
Progress: |##########################################################| Done.
Writing flash…
Erasing EEPROM…
After this the green led at the board continue blinkink as bootloader mode, Itried to plug in and unplug the usb cable
but it is the same, I have tried too cuse a reset with a button from MCLR to GND but it continue without running the aplication.
I hope someone to helpme.
Thankss.
Can you post a ZIP file of your entire MPLAB X project directory here so we can look at it?
- Amanda
