Beginner setup help on mac
hi there, i have a baby orangutan atmega328p and usb isp programmer plololu 1300. i have followed the instruction on pololu site and done everything, but when i type make program on my terminal it show as follow
[code]avrdude -p m328p -c avrisp2 -P /dev/tty.usbmodem00056023 -U flash:w:test.hex
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
avrdude done. Thank you.[/code]
please help. thanks
I am sorry you are having trouble communicating with the programmer. Can you tell me more about your setup? Which Mac OS are you using? How are you supplying power to the Baby Orangutan? Is the red LED lit on the programmer? Can you post pictures that show how you have everything connected? Can you also post output of ls /dev/tty.usb*?
-Jon
