Trying a test with a PING sensor (Parallax PING))) Ultrasonic Sensor #28015). I can’t seem to prime it to send a pulse. It’s getting the 5V power. Here’s the code. Any thoughts? Thanks!
-Tyler-
#include <pololu/orangutan>
OrangutanPulseIn PulseIn;
OrangutanAnalog analog;
OrangutanLEDs leds;
OrangutanMotors motors;
void loop ()
int microPulse =0;
int pingPin = 1;
// The PING))) is triggered by a HIGH pulse of 2 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
OrangutanDigital::setOutput(pingPin, LOW);
OrangutanTime::delayMilliseconds(2);
OrangutanDigital::setOutput(pingPin, HIGH);
OrangutanTime::delayMilliseconds(10);
// The same pin is used to read the signal from the PING))): a HIGH
// pulse whose duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
OrangutanDigital::setInput(pingPin, HIGH_IMPEDANCE);
microPulse = OrangutanPulseIn::getLastHighPulse(pingPin);
microPulse *= 5;
leds.red(HIGH); //led on
OrangutanTime::delayMilliseconds(microPulse);
leds.red(LOW); //led off
OrangutanTime::delayMilliseconds(900);
int main()
// setup();
while(1)
loop();
These pauses need to be changed to microsecond pauses. Also look at the rest of your program to make sure you are using the correct delay. There is a 1000 times difference between micro and milliseconds.
I still can’t seem to get a reading out of the sensor though. No response from it’s indicator light. I am using the Orangutan on-board LED as feedback for the PING pulses, but it stays lit continuously…
Here’s the new code:
//#include <OrangutanLEDs.h>
//#include <OrangutanAnalog.h>
//#include <OrangutanMotors.h>
OrangutanLEDs leds;
void loop ()
int microPulse =0;
int pingPin = 1;
OrangutanTime::delayMicroseconds(2);
OrangutanTime::delayMicroseconds(5);
microPulse *= 50;
int main()
// setup();
while(1)
loop();
It looks like using Orang Pulsin is more complex than simply calling the pulsin function. I’m guessing you need a call to OrangutanPulseIn::start, possibly others.
You have a construct similar to Arduino. If are using the Ardiuno libraries, there is a simple pulsin command that you could use.
I’m not much of an AVR user myself, so I couldn’t help you write your own. On PIC I could use something along the lines of:
A delay would be necessary for higher clock speeds, and micro second resolution, or a divider on the final result for slower clock speeds. There are better ways to do this (such as using a timer), but that is a quick and simple method that gets you up and running.
Yeah, I think you are right. I’ve tried incorporating the “start” command as well now. I am now getting the Ping indicator light to flash, so it seems to be sending the pulses, but I’m not getting anything out of the BabyO LED, which means I’m not able to access the length of the last high pulse. I’ve tried to keep it as close to the examples just to see if I can get it to work…
(I suppose the workaround you posted would suffice, but I would really love to use the Baby O library if I can… )
Can you post the most recent version of your code? One thing you might try to do is simulate the Ping pulse with one of the Baby O’s digital outputs and try measuring that. That way you can be sure that your problems aren’t being caused by the Ping.
Hi Ben, sorry I meant to post the code last time. I’m really just trying to get the onboard LED to flash, so there’s no much to simulate. The PING is getting it’s pulses, but I’m not sure about the pulses it sends back. I wish I had a better way to debug, but I don’t. I’m starting to play around with the sloscope a little…
PS, I did get the Ping to work on an Arduino, so the Ping itself should be OK.
OrangutanLEDs leds;
void loop ()
unsigned long pulse_width;
unsigned char pingPin = IO_D2;
//unsigned char pulseArray [] = {1,2};
//OrangutanDigital::setInput(pingPin, HIGH_IMPEDANCE);
OrangutanPulseIn::start((unsigned char[]) {pingPin}, 1);
pulse_width = OrangutanPulseIn::getLastHighPulse(pingPin);
unsigned long ledDelay = pulse_width * 250000;
OrangutanTime::delayMilliseconds(ledDelay);
int main()
// setup();
while(1)
loop();
The PulseIn library does not do that for you, so you should uncomment that line.
Your LED delay is ridiculously long:
You are trying to delay 250 seconds (4.2 minutes) for every quarter microsecond of Ping pulse length. Given that the Ping pulse length might be a few tens of milliseconds if your object is 10m away, that means you are potentially trying to delay for around 200 days. This won’t actually work, since the argument to delayMilliseconds() is a two-byte integer and limited to values from 0 to 65535, but even if it worked as you intended, it would not be very helpful.
Did you mean to divide by 4000? (4000 quarter microseconds is one millisecond.)
I’ve tried switching to an input first. I had commented it out in an effort to experiment around. Same with the delay. I’ve tried multiplying, dividing, diferent values, all with the same result: no LED reaction. The value I have in the code above was me trying to use some extremes to see if there was any change. Nope.
(actually, I get the faintest flicker out of it as the PING light pulses, but it is so dim, I think it is just spilling over)…
So… has anyone gotten a Ping Ultrasound sensor to work with the Baby O? If you could post your code, I would be most grateful… I still don’t seem to be able to “capture” the return pulse… thanks,
-Tyler-
Sorry for the delayed reply. I didn’t look at your code too closely the first time because I immediately saw two glaring errors that would explain why nothing was happening. Looking at it some more, I see at least two other problems:
getLastHighPulse() does not block execution while waiting for a pulse to finish. Rather, it just tells you how long the last high pulse was, and at the time you are calling it, there has not been a high pulse yet, so it will just return zero. Also, the “channel” argument to getLastHighPulse() is not the pin, it’s the index of the pulsePins array supplied to the start method. You should be doing something like:
while (!OrangutanPulseIn::newHighPulse(0)); // wait for the high pulse from the ping to end
pulse_width = OrangutanPulseIn::getLastHighPulse(0);
I haven’t tested this, but can you try something like the following for your program and see if it works?
OrangutanLEDs leds;
const unsigned char pingPin = IO_D2;
void loop ()
unsigned int ledDelay = pulse_width / 40;
OrangutanTime::delayMilliseconds(ledDelay); // should delay between 0.01 and 1.8 s
OrangutanPulseIn::stop();
int main()
setup();
while(1)
loop();
Using an LED for feedback makes debugging tough, however. If you have our USB AVR programmer, you could use it as a USB-to-serial adapter and send the actual measured pulse length back to the computer so you can have a better idea what’s going on.
Success! You nailed it. I did not know the channel was the array…
Thanks for your while command suggestion as well.
I would love to debug that way & I do have your USB AVR programmer. Can you elaborate on how to accomplish this? What software would I need on the PC to monitor the data from the programmer/Baby O?
The programmer’s USB-to-serial adapter feature is described in the user’s guide. You would need to connect the programmer’s TX and RX pins to the PD0 and PD1 pins on the Baby Orangutan, respectively. You will also need to make sure there is a common ground between the programmer and the Baby O. The Pololu AVR library has functions for serial communication that you could use to communicate with your computer.
If you still have questions or run into trouble getting it working, please let me know.
Thanks, I got it working, to a degree. I’m using hyperterminal. I got some characters like “hello” to work like this:
// send_buffer: A buffer for sending bytes on PD1/TXD.
char send_buffer[] = "hello";
// wait_for_sending_to_finish: Waits for the bytes in the send buffer to
// finish transmitting on PD1/TXD. We must call this before modifying
// send_buffer or trying to send more bytes, because otherwise we could
// corrupt an existing transmission.
void wait_for_sending_to_finish()
while(!OrangutanSerial::sendBufferEmpty());
void loop ()
// Set the baud rate to 9600 bits per second. Each byte takes ten bit
// times, so you can get at most 960 bytes per second at this speed.
OrangutanSerial::setBaudRate(9600);
wait_for_sending_to_finish();
OrangutanSerial::send(send_buffer, 6);
OrangutanTime::delayMilliseconds(1000);
But, I’m having trouble getting numerical output to work:
int send_buffer[] = {1,2,3};
void loop ()
OrangutanSerial::send(send_buffer, 3);
int main()
// setup();
while(1)
loop();
With this error:
rm -rf Serial_to_terminal_test.o test.elf dep/* test.hex test.eep test.lss test.map
Build succeeded with 0 Warnings...
avr-g++ -mmcu=atmega328p -Wall -gdwarf-2 -std=gnu99 -Os -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -MD -MP -MT Serial_to_terminal_test.o -MF dep/Serial_to_terminal_test.o.d -c ../Serial_to_terminal_test.cpp
cc1plus.exe: warning: command line option "-std=gnu99" is valid for C/ObjC but not for C++
../Serial_to_terminal_test.cpp: In function 'void loop()':
../Serial_to_terminal_test.cpp:35: error: no matching function for call to 'OrangutanSerial::send(int [3], int)'
c:/winavr-20100110/lib/gcc/../../avr/include/pololu/OrangutanSerial/OrangutanSerial.h:146: note: candidates are: static void OrangutanSerial::send(char*, unsigned char)
c:/winavr-20100110/lib/gcc/../../avr/include/pololu/OrangutanSerial/OrangutanSerial.h:166: note: static void OrangutanSerial::send(unsigned char, char*, unsigned char)
make: *** [Serial_to_terminal_test.o] Error 1
Build failed with 1 errors and 1 warnings...
I’m also not sure how to convert to following to C++, can you help me with that? It’s from the serial1 example. I’ve searched the internet to no avail…
If I use “char” instead of “int”, it builds OK, but the output on hyperterminal is " " (depending on the font), instead of “123”. I assumed it was because it thought it was a character instead of a number…
As for the memcpy_P call, I was just trying to get the example serial1 from the user guide to work. I was assuming it was because I was building it in C++… Here’s the complete code:
//#include <OrangutanLEDs.h> these are Arduino libraries
OrangutanLEDs leds;
char send_buffer[32];
void loop ()
memcpy__P(send_buffer, PSTR("Hi there!/r/n"), 11);
OrangutanSerial::send(send_buffer, 11);
int main()
// setup();
while(1)
loop();
ERRORS:
Build started 8.5.2012 at 19:47:48
../Serial_to_terminal_test.cpp:28: error: 'PSTR' was not declared in this scope
../Serial_to_terminal_test.cpp:28: error: 'memcpy__P' was not declared in this scope
Build failed with 2 errors and 1 warnings...
will not display “123” in hyperterminal. It displays the character code, which are non printing characters for 1 2 and 3, and a left brace “{” for:
char send_buffer[] = {123};
If you use
char send_buffer[] = {'1','2','3'};
then it should display “123”, as single quotes denote an encoded character, such that ‘1’ actually equals 49 in decimal.
I would also suggest using Br@y’s Terminal instead of hyperterminal. It’s designed for this type of work, and is much better in my opition. You can find it here: https://sites.google.com/site/terminalbpp/ It can also display binary, decimal, and hexadecimal in addition to encoded character output.
It sounds like you don’t understand how to send numbers over a serial connection. When you are using a typical terminal program such as hyper terminal, every byte received is interpreted as an ASCII character. To find the correspondence between bytes (0-255) and ASCII characters, just search Google for “ASCII code” or take a look at the chart at http://www.asciitable.com/. This will help you understand what’s going on.
What you need to do is convert your number into a string of bytes representing ASCII characters. Some characters will represent digits of your number, and other characters will be separators to make the numbers easier to read. The easiest way to do this is to use sprintf. Please try the following code. I didn’t compile it myself but I expect it to work:
#include <stdio.h>
char send_buffer[80];
int a = 1, b = 44;
void setup()
void loop()
OrangutanSerial::sendBlocking(send_buffer, sprintf(send_buffer, "a=%d b=%d\r\n", a, b));
int main()
setup();
while(1)
loop();
Cool, thanks to you both; it looks like I got it working. I’ll check out Br@y’s terminal. Thanks for the fsprint tip, I did not know about that.
Regarding fsprint, I got a warning if I tried to use an “unsigned long”. The warning said it was expecting “int”. Can fsprint only be used with int? How would you use fsprint with a combination of variables like unsigned long and int?
