Problem with red LED in POLOLU USB AVR PROGRAMMER‏
Hi
The problem is the following: when I connect the Pololu USB AVR programmer in any computer by USB port, the device turn on the Green led and this confirm that the device and drivers is ok. The problem is that the red led turn on blinking. According user guide the red led means problem or errors in device but is not clear for me what happend? Please your support explain me what could to be the problem?
P.D. Attached is The battery is 3,7 V. Also, you can see another picture with the error when I want to read the device with Atmel Studio 6.2.
As stated on the Baby Orangutan’s product page, the input voltage range of the Baby Orangutan is 5V to 13.5V, so you will not be able to power it with your 3.7V battery. Could you try powering your Baby Orangutan with at least 5V and programing it again?
